Using device templates to standardize configurations
kjdhghsghsfg
I'm running NSO 6.1.7.1 with juniper-junos-nc-4.12 NED.
I'm trying to use NSO device templates to standardize certain parts of device configurations.
In this particular case I'm trying to force a certain set of "apply-groups" on a given Junos configuration level. For example: I want the Junos devices to be configured like this:
protocols {
    ospf {
        apply-groups [ GROUP1 GROUP2 GROUP3 ];
It's easy to use device templates to add apply-groups. But I haven't found a way to delete them. For example if Junos device already has following config:
protocols {
    ospf {
        apply-groups [ GROUP1 GROUP2 GROUP3 GROUP4 ];
I haven't been able to figure out the way to delete GROUP4.
More specifically I would like to find a way to force the set of groups instead of configuring template to delete GROUP4, because on some other device there might be, for example, GROUP5. And I don't want to check all of them manually...
For example I have tried to use the replace tag:
[edit devices template TEST2 ned-id juniper-junos-nc-4.12 config configuration protocols ospf]
user@nso-server% annotate ?
Description: OSPF configuration
Possible completions:
  apply-groups
  apply-macro
  area                 Configure an OSPF area
  backup-spf-options   Configure options for backup SPF
  domain-id            Configure domain ID
  graceful-restart     Configure graceful restart attributes
  spf-options          Configure options for SPF
  topology             Topology parameters
  traceoptions         Trace options for OSPF
  undocumented
user@nso-server% annotate apply-groups ?
  string  [
user@nso-server% annotate apply-groups "Tags: replace"
Error: the operation is not supported on 'devices template TEST2 ned-id juniper-junos-nc-4.12 config configuration protocols ospf apply-groups'
And equivalent in Cisco cli where the result is no error but the "! Tags: replace" does not appear in the template config.
I have succesfully used the "Tags: replace" in multiple other configuration stanzas.
Please advice
Or should I create a tac case and request enhancement?
Or am I trying to do something totally unsupported?
https://developer.cisco.com/docs/nso/guides/compliance-reporting/
huayyang
kjdhghsghsfg
Hi!
Thanks for the hint. Here's what I have tried so far. I cannot get it working either..
[edit devices template TEST2 ned-id juniper-junos-nc-4.12 config]
user@nso-server% tag add configuration protocols ospf apply-groups [ GROUP1 GROUP2 GROUP3 ] replace
Error: internal error
[error][2024-04-25 14:07:06]
Or:
user@nso-server% tag add apply-groups replace
[error][2024-04-25 14:14:22]
Or:
user@nso-server% tag add apply-groups [ GROUP1 GROUP2 GROUP3 ] replace
[error][2024-04-25 14:15:11]
Or equivalent in cisco cli
user@nso-server(config)# do show running-config devices template TEST2
config
user@nso-server(config)# devices template TEST2
user@nso-server(config-template-TEST2)# ned-id juniper-junos-nc-4.12
user@nso-server(config-ned-id-juniper-junos-nc-4.12)# config
user@nso-server(config-config)# ! Tags: replace
user@nso-server(config-config)# configuration protocols ospf apply-groups [ GROUP1 GROUP2 GROUP3 ]
user@nso-server(config-config)# top
user@nso-server(config)# show conf
% No configuration changes found.
user@nso-server(config)# commit
% No modifications to commit.
config
