'wait-for-lock' by config or ncs.conf
Koji Yokoe
Hi. I want an advice from someone who are familiar with 'wait-for-lock' which has been implemented since NSO 4.4.2 as follows.
- ncs: 'sync-from'/'sync-to'/'check-sync'/'partial-sync-from' actions now
have a 'wait-for-lock' parameter that can be used to specify a timeout
that the action waits until the device lock is released and any commit
queue items that contain the device are done. If the 'wait-for-lock'
parameter is not specified, the action will fail immediately for the
device if the lock is taken for the device or if the device is placed
in the commit queue.
A commit now use the /devices/global-settings/commit-retries to wait
for any device lock to be released.
(Issue tracker: #27591)
When compare-config and sync-to are executed almost at the same time (compare-config first, sync-to second), sync-to fails as follows because device is locked in a compare-config-operation.
# devices device R1 sync-to
result false
info R1: Device is locked in a compare-config operation by session 328060
This can be solved by adding 'wait-for-lock' option as follows.
# devices device R1 sync-to wait-for-lock { timeout 60 }
# (Success after waiting for device unlocked)
I was expecting this is also achieved by /devices/global-settings/commit-retries setting because above statement says so.
(config)# devices global-settings commit-retries timeout 60
(config)# commit
Commit complete.
But it doesn't work as follows.
result false
info R1: Device is locked in a compare-config operation by session 328630
Is it any way to achieve it by config or ncs.conf setting?
gmuloche
According to the YANG model in my NSO 5.2.0.3 install for devices you can configure it at the global-settings level:
  revision 2019-04-09 {
    description
      "Released as part of NCS-5.1.
       Added 'wait-for-lock' choice under
       'device-profile-parameters'
       grouping.
And the mentioned grouping:
    grouping device-profile-parameters {
      description
        "A set of parameters to use when communicating with a device.
         These parameters can be set on:
           o  global-settings
           o  device-profile
           o  device
         If a parameter is set on the device, its value is used.
         Otherwise, if the paramater is set in the device's
         device-profile, its value is used.  Otherwise, the global
         setting is used, if set.  Otherwise, the value used depends on
         the NED type.";
      uses timeouts;
      uses wait-for-lock{
          refine wait-for-lock-choice{
            description
              "When an action accepting the wait-for-lock parameter is
               called without providing the wait-for-lock parameter, the
               wait-for-lock-choice device setting is going to be used.";
I checked NSO 4.7.4.2 YANG model and this is not present so it seems you can achieve what you want starting with NSO 5.1
gmuloche
    description
       grouping.
      description
           o  global-settings
           o  device-profile
           o  device
         the NED type.";
      uses timeouts;
      uses wait-for-lock{
            description
Hi Guillaume.
Thank you for your kind advice.
Yes. You are right. In NSO 5.2.0.3, I could configure 'wait-for-lock' and it worked as expected.
Here is a log from my test.
admin@ncs# show ncs-state version
ncs-state version 5.2.0.3
First, I executed 'compare-config'
admin@ncs# devices device vCPE001 compare-config
Right after this, I executed 'check-sync'. It failed as I expected due to the lock by 'compare-config'
admin@ncs# devices device vCPE001 check-sync
result error
info vCPE001: Device is locked in a compare-config operation by session 39
Then I added 'wait-for-lock' option to the command.
Of course it works (same as NSO 4.7)
admin@ncs# devices device vCPE001 check-sync wait-for-lock { timeout 60 }
result in-sync
Then I configured 'wait-for-lock' which is newly implemented at NSO 5.x
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# devices global-settings wait-for-lock timeout 60
admin@ncs(config)# commit
Commit complete.
admin@ncs(config)# exit
Then I executed check-sync without 'wait-for-lock' option right after compare-config.
It worked as I expected.
result in-sync
I would be glad if it was implemented at NSO 4.x
Thank you again Guillaume
