Want to execute an NSO command with two parameters through python api
Shashank Srivastava
I am working on a task in which I need to download a file and then upload the same on the device after making some changes. I can download the file easily by using scp-from python api as shown in python code snippet.
However, the issue is with sending multiple parameters. I want to execute following command through python api and send two parameters local-file and remote-file through python api.
devices device edgemarc1 scp-to local-file dummy remote-file /etc/conf/dummy
I know we can execute single parameter command through below piece of python code but I am unable to figure out how to send two parameters through python api .
scp_from_cmd = devs[devicename].scp_from.remote_file
inp = scp_from_cmd.get_input()
inp.args = ['/etc/config/fw_defs.conf']
response = scp_from_cmd.request(inp)
Any guidance is appreciated.
Shashank Srivastava
rogaglia
Best is to use ncs_pycli that will give you tab access to all the model:
In [3]: input = device.scp_to.get_input()
In [4]: input.local_file="test"
In [5]: input.remote_file="test2"
In [6]: result=device.scp_to(input)
rogaglia
Thanks for this wonderful solution! Works well
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
