12-28-2018 06:57 AM - edited 03-01-2019 04:15 AM
Looking for suggestions to support multi-factor authentication via Yubikey/RSA SecureID for the Web UI. The customer is currently using PAM authentication with NSO. Network devices use multi-factor authentication (through Cisco ISE) for direct CLI logins, but NSO users are mapped to a common network device user which does not require multi-factor as an interim solution. So that multi-factor is still in the "path" to device access the customer wants to ensure that the Web UI supports it in some fashion.
Any suggestions are greatly appreciated.
Somewhat related: Cisco has some pretty good documentation for setting up multi-factor device authentication using ISE using RADIUS RFC-3865 Compliant token servers for Yubikey/RSA SecureID...
01-02-2019 01:21 PM
You could take a look at /ncs-config/aaa/external-authentication/
In the tailf-ncs-config.yang file:
1762 container external-authentication {
1763 presence "";
1764 leaf enabled {
1765 type boolean;
1766 default false;
1767 description "
1768 When set to 'true', external authentication is used.";
1769 }
1770 leaf executable {
1771 type string;
1772 description "
1773 If we enable external authentication, an executable on the
1774 local host can be launched to authenticate a user. The
1775 executable will receive the username and the cleartext
1776 password on its standard input. The format is
1777 '[${USER};${PASS};]\\n'. For example if user is 'bob' and
1778 password is 'secret', the executable will receive the line
1779 '[bob;secret;]' followed by a newline on its standard
1780 input. The program must parse this line.
1781
1782 The task of the external program, which for example could
1783 be a RADIUS client is to authenticate the user and also
1784 provide the user to groups mapping. So if 'bob' is member
1785 of the 'oper' and the 'lamers' group, the program should
1786 echo 'accept oper lamers' on its standard output. If the
1787 user fails to authenticate, the program should echo
1788 'reject ${reason}' on its standard output.";
and for the external-validation:
1842 container external-validation {
1843 presence "";
1844 leaf enabled {
1845 type boolean;
1846 default false;
1847 description
1848 "When set to 'true', external token validation is used.";
1849 }
1850 leaf executable {
1851 type string;
1852 description
1853 "If we enable external token validation, an executable on the
1854 local host can be launched to validate a user. The
1855 executable will receive a cleartext token on its standard
1856 input. The format is '[${TOKEN};]\\n'. For example if the token is
1857 '7ea345123', the executable will receive the string '[7ea345123;]'
1858 followed by a newline on its standard input. The program must parse
1859 this line.
1860
1861 The task of the external program, which for example could
1862 be a FUSION client, is to validate the token and also provide
1863 the token to user and groups mappings. Refer to the External
1864 validation section of the AAA chapter in the User
1865 Guide for the details of how the program should report the
1866 result back to NSO.";
1867 }
So, when you configure external auth, as it prompts for user/pass in the WebUI, it should communicate to the external server to validate authentication.
Let me know if this helps.
01-03-2019 09:24 AM
Thanks. I will look into this. I am also looking into the RSA Authentication Agent for PAM or running an NGINX web proxy with support for Yubikey PIV certificate/SecureID OTP authentication in front of NSO.
01-03-2019 09:16 PM
