Xpath expression error
kerim mohammed
Level 3
Level 3
I have the following xpath expression in yang. I keep on getting syntax error when compiling:
list device-if {
        key "device-name";
        leaf device-name {
            type leafref {
                path "/ncs:devices/ncs:device/ncs:name";
        leaf interface {
            type string;
            must "not (/ncs:services/vlan:vlan[vlan-id != current()../../vlan-id]/device-if[device-name = current()../device-name][interface = current()])" {
                error-message "this interface is in use";
Syntax error upon compilation:
/root/./ncs4.6-install//bin/ncsc  `ls vlan-ann.yang  > /dev/null 2>&1 && echo "-a vlan-ann.yang"` \
      -c -o ../load-dir/vlan.fxs yang/vlan.yang
yang/vlan.yang:39: error: XPath error: XPath syntax error
make: *** [../load-dir/vlan.fxs] Error 1
frjansso
Hi!
I think the error is this part: .../[vlan-id != current()../../vlan-id]/...
I think you may need current()/../../vlanid
Please note the extra slash after current().
frjansso
Hi!
thank you! that fixed it.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
