xpath nested deref iterates through every cdb device
ryan-hitch
Level 4
Level 4
I noticed in xpath.trace that the following leafref iterates through every GigabitEthernet interface on every device in the CDB to constrain the "must" down to just GigabitEthernet interfaces on the current device. This seems very inefficient and introduces quite a bit of delay (several seconds) while leafref values are being constrained to the current device. Is there a better way to do this so that the device is selected prior to the interface search?
        list switch-interfaces-GigabitEthernet {
          key switch-interface-id;
          when "../switch-interface-type = 'GigabitEthernet'";
          leaf switch-interface-id {
            tailf:info "The switch interface identifier";
            type leafref {
              path "/ncs:devices/ncs:device/ncs:config/ios:interface/ios:GigabitEthernet/ios:name";
           must "current()=deref(deref(current()/../../../switch-name))/../ncs:config/ios:interface/ios:GigabitEthernet/ios:name;
            // ../../../switch-name is a leafref to "/net-topo:net-topo/net-topo:switch/net-topo:switch-name"
            // net-topo:switch-name is a leafref to "/ncs:devices/ncs:device/ncs:name"
Aha, can you try this path, please note it's pseudo and probably needs some massage
/ncs:devices/ncs:device[ncs:name=../../../switch-name]/ncs:config/ios:interface/ios:GigabitEthernet/ios:name
5 Replies 5
frjansso
If I understand you correct, you want the leafref to an interface on the device referenced by switch-name, if that's the case I'd change the leafref to something like this
path "deref(../../../switch-name)/../ncs:config/ios:interface/ios:GigabitEthernet/ios:name"
and get rid of the must statement.
I have been unable to figure out the proper leafref path syntax to get this working as switch-name in this example requires a nested deref which the compiler complains is invalid syntax for a path statement (one deref in a path statement works fine, but not two).
../../../switch-name is a reference to "/net-topo:net-topo/net-topo:switch/net-topo:switch-name
net-topo:switch-name is a reference to "/ncs:devices/ncs:device/ncs:name"
path "deref(deref(current()/../../../switch-name))/../ncs:config/ios:interface/ios:GigabitEthernet/ios:name" // errors out on compile with a "should be of type path-arg error"
Thanks Fredrik! The following did it:
/ncs:devices/ncs:device[ncs:name=current()/../../../switch-name]/ncs:config/ios:interface/ios:GigabitEthernet/ios:name
Awesome!!
