yanger swagger: option for https BaseURL
rogaglia
I am using yanger to create the swagger documentation. I do not find a way to force the BaseURL to be https and not http and I need to change that by script.
Am I missing anything?
Roque
perander
What are you using together with pyang? I can't find any default option or plugin to generate Swagger with it.
Ups type. I meant Yanger.
I am interested in changing a couple of things:
- force https (less priority as I can simply manually edit one field BaseUrl in Postman)
- Change Authentication mechanism. I would like to set it to "Inherit auth from parent" in all API calls, so I set the credentials in a single place.
Do you know if either of them are possible?
The available schemes are hard coded to the list ["http", "https"] in Yanger. Does it help manually editing the "schemes" in the Swagger file, i.e setting it to only ["https"]?
Regarding inheriting auth from parent, this seems to be a Postman feature/option and not specific to Swagger? I don't know about your use case, but perhaps you can set up external token authentication for RESTCONF?
