Nicklas Wagerth
Community Manager
Community Manager
Testing Automation for a generic NSO Service Provisioning Package
Davide Zennaro, Consulting Engineer, Cisco Systems
Abstract
The development of high-quality NSO packages also results from extensive testing. In this session, Cisco CX will share its experience on how using Cisco CXTA keywords and the Robot framework with a general (not package or test case-specific) approach internally has enabled to test of multiple NSO service provisioning packages using the same robot codebase. In this case, and as per Cisco CX experience, the flexibility, code re-usability, and possibility to add new packages to the testing process without writing any new robot code definitely overcome the disadvantages coming from the additional robot code complexity.
About the Speaker
Davide Zennaro is a Consulting Engineer in Cisco CX, based in Italy. He likes working in team and considers it an essential factor in order to achieve great results. He is passionate about code development and enjoys automating repetitive tasks. He works in the delivery of network automation and has led a small team in the development and maintenance of an internal Testing Automation tool used to test NSO packages.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
