09-19-2022 11:57 AM
Hello all,
I am having several issues with a two stack C9200 switch. The first issue is when it is given a power cycle it will fail to boot to cat9k_lite_iosxe_npe.17.03.05.SPA.bin three times before successfully loading. Now i think that might also hinder me getting in to ROMmon mode because it automatically power cycles and it cannot be stopped. Secondly, I have followed this article System Management Configuration Guide, Cisco IOS XE Gibraltar 16.10.x (Catalyst 9200 Switches) - Troubleshooting the Software Configuration [Support] - Cisco with no success on both switches, i have tried these steps on each with and without the stacking cable plugged in. I will paste bellow copies of my issues along with the last config i was able to pull before i was locked out. The other issue is i set the password and i know what it is but i never set the username (i was gathering information for it) and the terminal session restart prompting for a username that was never set with my password
Initializing Hardware...
System Bootstrap, Version 17.5.1r [FC4], RELEASE SOFTWARE (P)
Compiled Wed 01/06/2021 18:21:57 by rel
Current ROMMON image : Primary
C9200-48P platform with 4194304 Kbytes of main memory
RAM test aborted by console.
boot: attempting to boot from [flash:]
boot: reading file
user is not a regular file
boot: failed to load flash:/user
ERROR: failed to boot from flash: (Not Found)
Please wait while the system restarts.
boot: reading file
boot: reading file
boot: attempting to boot from [flash:cat9k_lite_iosxe_npe.17.03.05.SPA.bin]
boot: reading file cat9k_lite_iosxe_npe.17.03.05.SPA.bin
boot: failed to load flash:/user/cat9k_lite_iosxe_npe.17.03.05.SPA.bin (Aborted)
ERROR: failed to boot from flash:cat9k_lite_iosxe_npe.17.03.05.SPA.bin (Aborted)
switch:
switch:
switch: dir flash:
Attributes Size Name
-rw-r--r-- 2149 boothelper.log
-rw------- 0 dope_hist
drwxr-xr-x 4096 .installer
drwxr-xr-x 4096 .rollback_timer
-rw-r--r-- 592 bootloader_evt_handle.log
drwxr-xr-x 4096 core
drwxrwxrwx 4096 .prst_sync
drwxrwxrwx 4096 gs_script
-rw-r--r-- 5242880 ssd
drwxr-xr-x 4096 ss_disc
drwxr-xr-x 4096 tech_support
drwxr-xr-x 4096 dc_profile_dir
-rw-r--r-- 916 vlan.dat
drwxr-xr-x 4096 sys_report
drwxr-xr-x 4096 .USWAP
drwxr-xr-x 4096 .CRFT
-rw-r--r-- 134458 memleak.tcl
drwxr-xr-x 4096 Tbot
lrwxrwxrwx 13 NVRAM -> /flash1/NVRAM
drwxr-xr-x 4096 .dbpersist
-rw-r--r-- 15500 rdope_out.txt
-rw-r--r-- 89 rdope.log
drwxr-xr-x 4096 onep
drwxr-xr-x 4096 pnp-info
drwxr-xr-x 4096 license_evlog
drwxr-xr-x 4096 .rommon_sync
drwxr-xr-x 4096 guest-share
-rw-r--r-- 2097152 nvram_config
-rw-r--r-- 2097152 nvram_config_bkup
drwxr-xr-x 4096 pnp-tech
-rw-r--r-- 476847429 cat9k_lite_iosxe_npe.17.03.05.SPA.bin
-rw-r--r-- 2149 boothelper.log.old
switch: nvram_config ?
Error: command 'nvram_config' not found. Use 'help' to list commands.
switch: ?
arp Dump or Clear ARP Table
boot Load and boot an executable image
cat Display text content from a file
copy Copy a file
dir List filesystems or a directory on a filesystem path
help List command information
history Show command history
idprom Show idprom data
ping Ping use ICMP protocol to get an ICMP ECHO_RESPONSE from host
ping6 Ping use ICMP protocol to get an ICMP ECHO_RESPONSE from host
reset Reset entire system
set Set an environment variable value
unset Unsets an environment variable
version Show sboot version and runtime info
And to make matters more fun my Win10 device blue screened and restarted itself and removed my config file for the switch before I could save it. but I do know the password and I did spell check it before hand. **Note: I have tried base usernames like "cisco" and "admin" with no avail obviously or I would not have posted this lol. Anyways any guidance would be greatly appreciated. I have tested also through Console and SSH
Thank you for any help you can provide, sorry for the lengthy post.
Solved! Go to Solution.
09-20-2022 04:52 AM
So do the following:
conf t
no system ignore startupconfig switch all
end
wr
09-19-2022 12:13 PM
here is also a copy of the "switch: version" if that would help anything
switch: version
09-19-2022 03:39 PM
Post the complete output to the command "set".
09-20-2022 04:36 AM
switch: set
ABNORMAL_RESET_COUNT=0
AUTO_SWITCH_CONSOLE_DISABLE=0
BAUD=9600
BOOT=flash:;flash:cat9k_lite_iosxe_npe.17.03.05.SPA.bin;
BSI=0
MAC_ADDR=68:87:C6:77:C1:80
MANUAL_BOOT=no
MODEL_NUM=C9200-48P
MOTHERBOARD_SERIAL_NUM=JAE25440SPA
RANDOM_NUM=1643166669
ROMMON_BOARDID=0x2320
ReloadReason=Image Install RET_2_RCALTS=1635717946
SWITCH_NUMBER=1
SYSTEM_SERIAL_NUM=JAE25440SPA
TEMPLATE=advanced
switch:
09-20-2022 04:40 AM
here is the output with hidden variables as well
switch: set -a
AUTOBOOT_COUNT=0
AUTOBOOT_STATE=0
BAUD=9600
BSI=0
CLEI_CODE_NUMBER=INM9200ERB
MANUAL_BOOT=no
MODEL_NUM=C9200-48P
MODEL_REVISION_NUM=C0
MOTHERBOARD_ASSEMBLY_NUM=73-20259-03
MOTHERBOARD_REVISION_NUM=A0
POE_DB_INFO=73-102420-02A0JAE25440ASQ
ROMMON_AUTOBOOT_ATTEMPT=3
ROMMON_BOARDREV=0x3
SWITCH_NUMBER=1
TAN_NUM=68-103044-01
TEMPLATE=advanced
USB_DB_INFO=73-18785-04A0JAE25430X2D
VERSION_ID=V03
manual_boot=yes
**note: i typed int "switch: set manual_boot=yes" but unsure if it will override the "MANUAL_BOOT=no"
09-20-2022 04:52 AM
conf t
end
wr
09-20-2022 05:16 AM
Entered in command, switch loaded back into Running configuration with the username prompt. I am going to try again, My work computer also restarted with a blue screen (got to love windows i should make it into a Linux PC but that is a different issue) im going to load these commands again and ill update further.
09-20-2022 05:26 AM
confirmed command in both switches on the stack
also confirmed in both "dir flash:" the IOS is intact
switch:
switch: set
BAUD=9600
BSI=0
MANUAL_BOOT=no
MODEL_NUM=C9200-48P
RANDOM_NUM=119938735
SWITCH_IGNORE_STARTUPCFG=1
SWITCH_NUMBER=1
TEMPLATE=advanced
manual_boot=yes
switch:
switch:
switch: set
BAUD=9600
BSI=0
MAC_ADDR=68:87:C6:EB:F0:80
MANUAL_BOOT=no
MODEL_NUM=C9200-48P
MOTHERBOARD_SERIAL_NUM=JAE25440QRR
RANDOM_NUM=1032080692
ReloadReason=Image Install RET_2_RCALTS=1635719526
SWITCH_DISABLE_PASSWORD_RECOVERY=0
SWITCH_NUMBER=2
SYSTEM_SERIAL_NUM=JAE25440QRR
TEMPLATE=advanced
nvram_config=0
switch:
