Stuck on Configuring a Fully Specified Static Routing on both routers.
tempereke
Hello, I am quite stuck on configuring a fully specified static routing on both routers on this packet tracer problem, I always get "Inconsistent address and mask". If anyone could guide me in configuring fully specified static routing, that would be awesome. Thank you.
Are you looking subnet routing or host route ?
host route example :
Router(config)#ip route 192.168.2.254 255.255.255.255 192.168.1.254
subnet  route example :
Router(config)#ip route 192.168.2.0 255.255.255.0 192.168.1.254
BB
balaji.bandi
This means that  you entering wrong routing information,
what device you getting this message, what syntax you using ?
BB
I'm trying to configure Router0 first, when I try some to test it its either Inconsistent address or Invalid.
This is the last syntax that I tried "Router(config)#ip route 192.168.2.254 255.255.255.0 f0/1 192.168.1.254"
I tried to follow the slide samples but I cant make it work.
BB
