08-08-2019 11:24 PM
Hi everyone,
I just created a user (Name and email address) as bypass user to allow that person to enjoy Netflix.com. The next time the user opens Netflix.com, how does OpenDNS validate the user?
I also created a Bypass Code that anyone can use for Netflix, but every time I go to Netflix, it does not prompt me to enter the code. It just displays the site as blocked
Sorry, netflix.com has been blocked by your network administrator.
08-09-2019 02:06 AM
In case your question relates to a Netgear router with Live Parental Controls enabled, follow these instructions, especially from step 10 on. You will find that you must install Netgear Genie where you want to use bypass accounts, and that you must use Genie to login to a bypass account.
If your question does not relate to Netgear LPC, then specify what you're talking about.
08-09-2019 07:20 AM
L8 is me or the end user and probably not the sytem.
After adding user and applying it to the right policy/group, user is still receiving page block. How does openDNS can recognize the user so it can allow her to by pass.
Also, the bypass code is also not working. After adding a code, I still get page block. I have the feeling that I am still missing a step or two to make these two options to work.
thanks
08-09-2019 07:26 AM
You still didn’t say what OpenDNS service you‘re using, but it’s probably Umbrella. You open a support ticket, link “Submit a request“ above. We other home users cannot help here.
08-09-2019 07:30 AM
Apologies, yes it is Umbrella. I do have a ticket open but they are sending me links to fix it and the fix is not working. My incident is still open. After I created the the bypass code, I cannot find how to apply "linked Policies" to code
