09-13-2016 01:16 PM
I had an old computer that was using opendns client, but as I did remove this device, I would like to delete its browsing history. is that possible?
thanks,
09-13-2016 01:43 PM
OpenDNS does not log browsing history. It only logs DNS lookups that are sent to it's servers. The two are related, but they are quite different. If you want to delete the browsing history you need to do that on the computer itself. If you want to delete DNS logs from OpenDNS you can do that as well.
However, since OpenDNS Home does not log activity for specific devices, only for your entire network you cannot delete the DNS lookups for that specific device. You'll either need to purge all of it, or wait until the last of the DNS lookups expire out of the logs.
09-13-2016 01:53 PM
thanks,
sorry, I did not explain correctly. I want to delete the DNS logs from an specific device that was using Umbrella roaming device client. In that way, there is a log per device as well per network entries.
Is that possible to purge that?
thanks,
09-13-2016 01:57 PM
You would be better of posting in the Umbrella forum. As this one is mainly used for OpenDNS Home most of the people here, including myself, are unfamiliar with the specific workings of Umbrella.
