how to block inappropriate websites
zacman57
I would like to learn how to block inappropriate, undesirable websites such as pornography, etc.
mattwilson9090
Level 4
Level 4
You block those types of sites the same way you do with anything else that OpenDNS can block. Go to the homepage at www.opendns.com and then choose the appropriate option, which is more than likely the "Learn More" button under Personal. From there answer the questions or make choices and it will guide you through a basic setup and configuration for OpenDNS.
If you have specific questions or problems following that ask them here.
