07-20-2016 11:36 AM
I'm having trouble logging in my 15454 M6. The attachment is the error message that I kept getting. What should i do to fix this problem? Thank you in advance.
Solved! Go to Solution.
07-22-2016 12:54 AM
Hi, try
- in CMD: javaws -uninstall (delete CTC cash)
- SW than HW reset of TNC\TSC cards
- remove LCD and TNC\TSC
- perform in VxWorks (telnet conn.)
flmDeleteDB
- insert TNC\TSC then LCD
- try login
07-20-2016 12:32 PM
Feedback forum is dedicated to other topics. Moved to more appropriate community.
07-22-2016 12:54 AM
Hi, try
flmDeleteDB
- try login
07-28-2016 10:34 AM
Hi kayukovvalera,
Thank you for help! That worked!
