What maximum size of flash does Cisco 2610 router support
Shahzaib Khan
Dear All,
I want to upgrade the size of my flash memory module. Currently its size is 32 MB. Can anyone tell me how much i can increase its size. Further i am in confusion of the shape of flash module. I have attached the image of module which i think is flash. Please also confirm if it is flash of router 2610. Thanks
Best Regards
Shahzaib Khan
Marvin Rhoads
That's a very old router. Upgrading won't get you a lot of value.
I believe the picture you attached is a DRAM module, not flash memory. The router operates in DRAM and boots image off of the flash SIMM.
According to the product data sheet (here) there are various memory amounts supported, depending on your exact model.
