I have a system running under release 9.2.2.1 and consists of 3 X 10DME and 3 X PSM... I want to configure the PSM's as bi-directional revertive. Have read documentation that PSM are bi-drectional non-revertive.... Can I still modi...
Is it possible to change the wavelength configured in 10-DME module without disabling or deleting the active circuits? If so, how can this be done? thanks
Which system software load should I use for a 15454 DWDM using TCC2 controllers? Currently at R8.5.3 and I want to go to R9.4 but not sure which flavor of 9.4 to use. I have "ons15454.DWDM.K9.R9401", "ons15454.DWDM.Lite.K9.R9401", ...
Hi all,Currently I have a 4510R-E with supervisor6-E and TwinGig modules. I need to update connectivity up to 10Gbps and I was wondering which one to choose, the OneX Converter or X2-GB-SR. What are the difference betwen them if both apply to X2 port...
Gentlemen and optical experts.I've been put in a bit of a quanrdy by geography, and I need some input from those with more expertiese than I.My place of employ is putting a dark fibre between our DC and a client site, and we've just gotten back the e...
I've programmed my T1's however I'm having difficulty getting the T1's to attach to a PVC. I'm attempting to get multiple T1's over a single OC3 ATM connection. The ATM connection is up and working, for example I can CDP across the ethernet link I'...
Hi I want to configure it on the cisco DCT with the following speca can anyone help me to build the product configuration.•5.1.1 SDH multiplexer shall be installed in IT/Telecom room. It shall be capable of transmission and cross-connection of p...
Dear ALL, Currently we have a Core 6509 and several access switches 3550 , 3750 and 2960 and we are using multicore SFP GLC-SX-MM and GLC-LH-SM for uplink.We want to try out 1000Base-BX10-D and 1000BASE-BX10-U with a single fibre.Wi...
On the Cisco ONS routers, is there a relationship between#spr station-id 1 on the SPR interfaceandspr interface-id 1on the POS interface?I am a bit new to this system
Good day everyone,Im still kind of new to networking out new structures so bare with me. Im trying to find a the best solution for proformance, reliablity, best pratice. With the current equipement.What We have:Switches:2 - Cisco 3750 24P TS-S 1 - ...
Hi all,We have 6 mm fibre running from data center to 10th floor.Need to know what does 6 mm strand fibre mean?does it mean 3 pairs?thanksmahesh
I'm looking for a fiber switch to connect 8-12 computers via multi-mode @ 100mb. I also need the switch to act as a DHCP server. I'm looking at WS-C3750G-12S-S. I think this will do what I need. So here are my questions:Does this model require me...
Hi,We are looking to upgrade our ADSL broadband line to a fibre optic one soon. We are currently using an ISR 1921 router with an ADSL interface card (HWIC-1ADSL). Can somebody please advise us if this router is capable of handling a fibre optic line...
Hi,We are going to order two(2) cisco 4900M switches for core and twelve (12) 2960S switches for access (4 stacks with 3 switches each), connected to the core with 10G MM optical paths (up to 300M each). In addition I have one gigabit half-card but ...
- 9.2.1- two M6 terminal nodes, each node has 1 SMR1, 1 OPT17-AMP (used as booster), 1 PSM, 1 OTU2-TXP- PSM is used on each terminal to protect the outside plant- PSM COM goes to booster, PSM W goes to outside plant 1, PSM P goes to outside plant 2- ...
Subject | Author | Posted |
02-03-2025 08:10 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
