100mb SFP Module in Gigabit Cisco 3850
lccairns69489
I'm trying to simplify my network cabinet of historical works. The hardware is involved
Contemporary Controls Copper/Fibre switch - EISK8-100T/FC (lets say SW1 and SW2)
Cisco Catalyst C3850 12port fibre, with secondary copper rack. (call it SW3)
Currently setup is
SW1>fibre>SW2>copper>SW3
I would like to remove SW2 and go straight into SW3 to remove junk from my cabinet. so it would be SW1>fibre>SW3
Everything is MM, Full-duplex
I believe the issue as due to the speeds, SW1/2 is 10/100Base, and SW3 is Gigabit ports.
I have found a 100mb SFP module lying around but cannot for the life of me get the cisco switch to recognise the 100mb speed.
GigabitEthernet1/0/8
Full-duplex, 1000Mb/s, link type is auto, media type is DWDM-3819 SFP
the Module is
Westermo 1100-013 1/3
Multimode/155mbps/1310nm
So the I think the questions are
- what SFP module so I need?
- Do I need to configure it or does it recognise the SFP module automatically?
- Or  do I need to upgrade SW1 to 1000mb aswell?
I have tried to config both 7 an 8 as below, setting the port to negotiate on 7 with no luck
Core.2#show interface giga1/0/8
GigabitEthernet1/0/8 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0c11.6731.9408 (bia 0c11.6731.9408)
Description: DISABLED
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
interface GigabitEthernet1/0/7
description Wannac 4
switchport access vlan 15
switchport mode access
macro description Disabled-Port | Disabled-Port
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/8
description DISABLED
switchport nonegotiate
kubn2
This really depends on the SFP modules that you have, some modules like 100/1000BASE-LX SFP support 2 speeds however most popular SFPs are single speed only, you can try setting speed on the gigabit interface to 100Mb/s and try then but again it might not be supported.
Marvin Rhoads
The DWDM-3819 SFP is a 1 Gbps-only transceiver that requires single mode fiber and a matching same-wavelength transceiver at the other end. While compatible with your 12-fiber-port Catalyst 3850, it is not a general purpose transceiver that's interoperable with just any other 1 Gbps transceiver. It is specialized for use with systems where your upstream device is using Dense Wave Division Multiplexing (DWDM) for transport. It can also only operate at 1 Gbps. To operate at 100 Mbps, you would need something like a GLC-GE-100FX at the Catalyst end.
Here are the references I used to answer your question:
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/dwdm-transceiver-modules/datasheet-c78-382891.html
https://tmgmatrix.cisco.com/?npf=112
