10Gb BIDI for MMF on OM4 for short hauls (10Gb on single fiber strand of MMF)
gp1200x
Level 2
Level 2
Anyone have any knowledge of whether there exists such a transceiver that will allow 10gb BIDI on MMF runs that works in Cisco devices?  I have Gb transceivers but have not found any 10Gb. I am looking for optics that I could use on OM4 MMF for short hauls like 300-400M. I am thinking of trying some BIDI LR at 1300nm to see what happens since SFP+ LRM can be used on MMF for short hauls up to 300M and the wavelength is close. 40Gb is not an option and I know they have optics for that. FS.COM doesn't appear to have a solution for me....maybe technically it can't be done or done cheaply.  Thanks
Calin C.
Level 5
Level 5
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
These are all the 10Gb SFP+ ones supported by Cisco and there is none for MMF.
If you can give it a try, without big spending on the budget, using with SMF BD on MMF Fiber:
https://community.cisco.com/t5/optical-networking/can-i-connect-single-mode-sfp-glc-lh-sm-to-multimode-fiber-which/td-p/1914210
Not exactly the same situation, but seems to work.
From my own experience, it works...sometimes :)
