15252 CLIP client side
markschnabel
Level 4
Level 4
Can the client accept either SM or MM -SC GigE connections?
thanks
mark
bkurtzer
Hi Mark:
I just read your message and noticed that no one had answered.
On the ONS15200 (Rx) you can only use SM fiber or 50u MM fiber - see attached file.
On the Tx side you can use SM and both 50u/125 MM and 62.5u/125.
Hope this helps,
Ben
