We use 15454 MSPPs (r9.0) on our network.
We're interested in buying ML-MR-10 cards because it provides switching capabilities and aggregation.
We want to use these cards to connect to a third-party using POS.
This third-party network only supports POS encapsulation types HDLC and PPP and does NOT support GFP.
For what I've read, the ML-MR-10 supports only GFP encapsulation type for SONET.
Can someone confirm that please?
If ML-MR-10 car cannot support HDLC or PPP for POS, which card should we use instead? ML1000-2?
BRGs,
KD
Reviewing the Config Guide (link below)
Framing Mode, Encapsulation, and CRC Support
The ML-Series cards on the ONS 15454 and ONS 15454 SDH support two modes of the POS framing mechanism, GFP-F framing and HDLC framing (default). The framing mode, encapsulation, and CRC size on source and destination POS ports must match for a POS circuit to function properly. "POS on ONS Ethernet Cards," explains the framing mechanisms, encapsulations, and cyclic redundancy check (CRC) bit sizes in detail.
Supported encapsulation and CRC sizes for the framing types are detailed in Table 8-3.
Hello Tom,
Actually, in the documentation "Configuring POS" (which you refer to), I read that this chaoter applies to the ML-Series but only for ML100T-12, ML100X-8 and ML1000-2 cards (1st line).
There is another document "Configuring POS on the ML-MR-10 Card" in which I see that ML-MR-10 cards support only GFP-F encapsulation for SONET. See table 31-6.
Ther's also a note saying that the HDLC encapsulation can be configured on POS. However, the circuit does not come up and the configuration should be blocked.
http://www.cisco.com/en/US/docs/optical/15000r9_0/ethernet/454/guide/45490a_configposmlmr.pdf
I'm thinking about using a ML1000-2 instead of a ML-MR-10 card so it can interface with either a 3rd-party router or a Cisco 12000 GSR...
I'm a bit confused here and I don't know why the ML-MR-10 card would be the only one of the ML-Series that do NOT support HDLC or PPP for POS?
BRGs
KD
