날짜: 11-01-2022 05:55 AM
I've gotten all the other ports (10g and 100g) to correctly turn green when an sfp or qsfp is plugged in and doing "show controllers optics x/x/x/x" shows that the laser state is on so i know that its linking. For the 25g ports the led stays yellow when an sfp is plugged in, but if an sfp is plugged into the 25g port when you reboot the switch then the led is green or if you change an arbitrary setting for that port (i changed the description for example) then the led turns green. however if you do "show controllers optics x/x/x/x" for that port the laser state is off so i dont think its actually linking. Also "show controllers optics" shows that the tx power is -40 dbm which might be the issue because if you plug the same 25g sfp into a different switch it correctly links and the tx power is normal.
날짜: 11-01-2022 07:24 AM
- Are you using compatible SFP's listed in : https://tmgmatrix.cisco.com/?npid=2641 ?
M.
날짜: 11-01-2022 07:32 AM
yes, i'm using an SFP-25G-SR-S transceiver
날짜: 11-01-2022 08:07 AM
- Use latest software version (if applicable) : https://software.cisco.com/download/home/286324710/type/280805694/release/7.7.2
M.
날짜: 11-01-2022 08:37 AM
I can't upgrade the software version because I dont have a service contract. the version thats currently on the switch is 6.3.3
날짜: 11-01-2022 09:03 AM
날짜: 11-02-2022 09:03 AM
tx power is -40 dbm typically indicates the lack of signal on the fiber, Is the polarity correct (Tx/Rx)? Do you have a power meter to confirm whether the signal is present at the patch cord?
날짜: 10-03-2023 05:01 PM
Hello Cisco Community,
I Have the following unit PN: N540-24Z8Q2C-M V01 with version 7.4.2
does not recognize QSFP-100G-LR4-S in HundredGigE0/0/1/1 I get the following error.
#LC/0/0/CPU0:2023 Aug 10 22:55:01.959 GMT-6: optics_driver[294]: %PKT_INFRA-FM-3-FAULT_MAJOR : ALARM_MAJOR :OPTICS SUPPORTED_ERROR :DECLARE :0/0/CPU0: Optics0/0/1/1
When inserted in the other port Hun0/0/1/0 I get no errors
I was thinking maybe the controller is configured or disabled somehow. Any help is appreciated.
RP/0/RP0/CPU0:ios(config-if)#ipv4 address 2.2.2.2 255.255.255.0
RP/0/RP0/CPU0:ios(config-if)#no shut
RP/0/RP0/CPU0:ios(config-if)#end
Uncommitted changes found, commit them before exiting(yes/no/cancel)? [cancel]:yes
LC/0/0/CPU0:Oct 3 23:53:51.758 UTC: ifmgr[138]: %PKT_INFRA-LINK-3-UPDOWN : Interface HundredGigE0/0/1/1, changed state to Down
HundredGigE0/0/1/0 unassigned Shutdown Down default
HundredGigE0/0/1/1 2.2.2.2 Down Down default
RP/0/RP0/CPU0:ios#
RP/0/RP0/CPU0:ios#LC/0/0/CPU0:Oct 3 23:58:25.281 UTC: fia_driver[130]: %PLATFORM-DPA-2-RX_FAULT : Interface HundredGigE0/0/1/0, Detected Local Fault
LC/0/0/CPU0:Oct 3 23:58:25.281 UTC: ifmgr[138]: %PKT_INFRA-LINK-3-UPDOWN : Interface HundredGigE0/0/1/0, changed state to Down
LC/0/0/CPU0:Oct 3 23:58:25.516 UTC: optics_driver[235]: %L2-OPTICS-2-TRANSCEIVER_REMOVED : Optics module HundredGigE0/0/1/0 type QSFP28 100G LR4 removed
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
