Resolved! NCS 540 DAC compatibility
Hello,My NCS 540 (N540X-6Z18G-SYS-A) did not recognize a media non-cisco passive DAC 0.5m.Do you have some advices to resolve this problem ?And important, i can't buy a cisco DAC.
Hello everyone.I try to perform some tests with a SFP SFP-CH-OC3STM1-I on a ASR 920 with a Cisco IOS XE Software, Version 17.06.03. Marks it as not supported, *Feb 23 03:10:51.407: %TRANSCEIVER-6-INSERTED: C0/0: iomd: transceiver module inserted in G...
I am considering a C9606R for a solution. When it comes the line cards and interfaces I am looking at the C9600-LC-24C line card. When looking at the optics compatibility chart https://optics.cisco.com/?dr=7&dr=5&rh=18&npid=2223 I can see the vari...
Hi there,it's been a time i im with CLI oder http access to a cisco, so maybe u guys can help me out and have some patience with me, thanks !so whats going on ?I got a fiber connection from my ISP with EON fiber (germany) the UTM 9 firewall get the c...
Hi Team,I have a problem with compatibility between Cisco 2960 and GLC-FE-100FX. When I just installing the SFP, the port is err disabling.SWITCH_Y3_A#sh interface status errPort Name Status ReasonGi0/1 100FX err-disabled gbic-invalidAccording to com...
The initiative to move from catalyst to Meraki has started to happen due to cost and supply chain issues. in the Meraki switches you can get info about the sfp optic being used but can you get the transceiver detail info? When troubleshooting issues ...
What fields have to match between a server sfp and a switch sfp in order to determine they are both compatible? for example wave length , mmf...etc
Hello, We are considering buying the C9300-NM-2C network module card for our C9300X switch. The specs. on the data sheet doesn't' specify if this network module supports 10Gb port speed.I was wondering if anyone has and document that says that the ne...
Hello everyone, I need to password recovery for the cisco ONS 15305 R.3.0.The XTC board came from repair, the standard onscli password is not suitable.Cisco ONS 15305 End-of-Life Policy.Thanks in Advance.
Hi, What is the mail difference between SFP-10G-LR-S and SFP-10G-LR. I have tried to collect information from datasheet and other forums. But no details got.
Good morning everyone.I'm new on this CISCO chat, I have a problem with a N2K-C2232PP-10GE to connect to a server with SFP+ interface.I connect 2 SFP+ 10GB between the server and the N2K-C2232PP-10GE and up to here it hooks up, then I try to connect ...
Hi,we have a C3850 24XS with a SFP+ module connected to a DWDM on 1310nm standard port, 10G.If the carrier shutdown the link, we have a down on port connected to DWDM, but we have optical power on RX, the same optical power with port in UP state.Spoi...
Does anyone know if you can have a 10GBase-SR-S SFP+ connected to a 10GBase-SR SFP+? Specs look identical, just trying to get a definitive answer before purchasing.
What is the process to initiate a warranty claim for Cisco 10 MM SFP ? The clip is twisted and its not going or exiting from the System.
Apologies if this is far too simple a question for the community.I am using GLC-SX-MMD SFPs from an ex4300 to the IDFs. I understand what DOM is and the the difference between MM/MMD however am curious and having trouble searching the answer to what ...
Subject | Author | Posted |
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM | ||
03-27-2024 12:16 AM | ||
09-10-2023 08:07 AM | ||
08-03-2023 03:20 AM |
