2960S DOM (Digital Optical Monitoring)
karthikeyanm
Hi All,
While having conversation with Cisco engineer, he said its in future road map(but not commited) to support DOM over SNMP MIBs and DOM on CLI is supported as of now. But module compatiblity has no information on 2960S DOM support and Release notes of IOS 15.0(2) released last month don't include 2960S in DOM Support. Can anybody comment on DOM support 2960S and give reference on it?
-Karthik.
-HTH Karthik.
Marvin Rhoads
DOM support should be driven more by the transceiver capabilities than the switch it's installed on. See this list for DOM compatibility of all Cisco transceivers.
For the switch you're asking about, please see this section of the 2960S configuration guide. According to it, the command "show interfaces transceiver detail" is supported in IOS 15.0(2) on a 2960S. (as it was on much earlier versions - back at least as far as 12.2(25) according to the older guides).
As noted in my first paragraph, you will need a DOM-capable transceiver. There are a few compatible with the 2960S per the transceiver compatibility matrix (here) - most notably the GLC-SX-MMD. Note the more common GLC-SX-MM is NOT DOM-capable.
