01-25-2013 01:36 PM
Y cabling the optical protected uplink 150M circuit off the MUX
MUX ---< Primary and seconday router
Can this be done on the Cisco routers?
02-05-2013 04:05 PM
What model routers (need IOS version etc). and what is the physical interface on the routers that the cable will be connecting to?
02-05-2013 07:12 PM
If you are referring to Y-cable protection provided on the 15454, the Y-cable protection does not require a specific version of software on the interfacing hardware (router).
The Y-cable splits the Client optical signal (i.e. router or other device) and feeds it to two different transponder or muxponder cards in a 15454 DWDM system. The two transponder cards make the decision which will send the signal to the client interface, so as not to receive two signals at the same time.
Figure 9-32 Y-Cable Protection
Review the 15454 documentation for additional details. Section 9.14 "Y-Cable and Splitter Protection" of the Reference Guide provides a diagram and supported 15454 interface cards.
If this is not what you were referring to.... then never mind!
