3550 to 2960x fiber connectivty
vcisco2012
I am using 3550 switch with sx gbic  at one end and 2960x with glc-lh-smd at other end  but link is not coming up. In am using multimode fiber.
I have tried changing fiber cores but still the link is not coming up.
Pls  suggest ..
leo.laohoo
If you're using multi-mode fibre then the SFP in the 2960X should be GLC-SX-MMD.
leo.laohoo
Are you using the 1000Base-SX GBIC? If so that will not work.
The 1000Base-LX/LH GBIC might work if you've carefully planned and implemented the physical layer spans.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet09186a008014cb5e.html
Even though the GLC-LH-SMD transceiver can operate over multimode fiber for shorter spans (400-500m, depending on the core size), it operates at 1310 nm wavelength vs. the 850 nm nominal wavelength for the 1000Base-SX GBIC.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet0900aecd8033f885.html
vcisco2012
It worked ...
