Hi Can we connect GLC-LH-SMD (3850-12S) at one end and MGBLH1 (SG 350) at other End. Regards Nimit Puvar
I have a catalyst 2950. I am in need of a single fiber BIDI GBIC. Does Cisco have these or is there a compatible manufacturer?
Hello, I am curious to see if anyone has experience with AT&T ASE connections. We have a 250MB MIS circuit feeding internet to our main location, that internet feed is then pushed out to approximately 15 loacations via ASE circuits. Our ASE connect...
Hi, We are having some weird issue, where throughput is very low 2MB/sec between two hosts over the Single Model Fiber WAN link. On investigation, its found that our carrier port is configured as 10G/Auto negotiate and negotiating in 10G and my side...
Just received a new commercial carrier service providing oc-3c. We are using the service to interconnect two ONS 15454 MSPP nodes. When I try to provision a CE circuit across the link I get a TPT failure alarm. I have set the line configuration on t...
We all know that OM1 cable supports 10G up to 33m. What's the case if the distance exceeds 33m? will the link operate below 10G or it will not work at all? is there a chart showing the speed changes with different distance? The reason I am asking is...
Hi all, I have some doubt regarding compatibility of SFP module (GLC-SX-MMD) in SFP+ port in Nexus switch 3000 series The switch Nexus 3048 have SFP+ port, the compatibility matrix reported in data sheet document does not report the compatibility wit...
I'm looking for the I/O specs for the SFP-10G-SR-S. I know it's CML but what are the exact levels and thresholds? Are there any caps on the outputs? Can it run slower then 10G bps? The datasheet I found on the website doesn't show these details. ...
Hello, do someone now if is this compatible: Mellanox ConnectX-4 Lx 2x25GbE SFP28 Adapter with XL-MGB-SX (on cisco N5K). If you have some sfp transreciver compatibility web-site, please share it with me. Thanks
Hello, I want connect C3750E and C3850. The distance is about 1,5 metres. I have a X2-10GB-LR-Module and a SFP-10GB-LRM and MCPs too. The wavelength is the same -1310nm. But I think, the transmit power is different.Is this possible?
Hi cisco team. I have issuse when connect SFP 3rd party (ZyXel) to switch 4506. HCM-DC-Core-Cat4506-01#show hw-module slot 1 port-group Module Port-group Active Inactive------------------------------------------------------------- 1 1 Te1/1 Gi1/3-4 ...
Hello everyone, I work as network administrator in industry company and i am about to install our local network throughout the areas of the factory. i have designed my network with all the specification needed (see the attached file). i am going to ...
Hi, I am using 3550 switch with sx gbic at one end and 2960x with glc-lh-smd at other end but link is not coming up. In am using multimode fiber. I have tried changing fiber cores but still the link is not coming up. Pls suggest ..
Greetings, I have a few question as it pertain to SFPs and Distance. The current scenario is as follows: We have switches at training locations that are approx. 20-30 Kilometers from our core. We currently use SFP-10-LRs for most of our applications...
We have had some rat problems at one of our sites. For some reason they chew through our fiber that feeds our IDFs. I want to have a roll in stock so we can replace a run if necessary. I need 6 fiber, 62.5/125 mm, tight buffered fiber. I usually t...
Subject | Author | Posted |
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM | ||
03-27-2024 12:16 AM | ||
03-27-2024 12:09 AM | ||
09-10-2023 08:07 AM |
