4948E-10G generating traffic with no devices attached.
Kevin Hamilton
Hello All,
I have a 4948E-10G that doesn't have any devices attached,  but it does have a one port loopback and its generating traffic.  Is that normal?
Specifically, I have a SFP installed in Te1/49.  That SFP is attached to a fiber that goes out 13 miles and is looped back with a physical jumper at the far end.  We did this just to verify the fiber was good.  I'm seeing packets on the output and input, and they're all Multicast.  Is that normal?  See below.  Thanks Kevin.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
TenGigabitEthernet1/49 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet Port, address is 442b.0362.8130 (bia 442b.0362.8130)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLH
input flow-control is on, output flow-control is off
Last input 00:00:17, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 35
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1180 packets input, 171253 bytes, 0 no buffer
Received 1180 broadcasts (1180 multicasts)
1181 packets output, 171765 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Joseph W. Doherty
Cisco may be sending packets like CDP out by default. Further, if the port is defined as a switch port, rather than a routed port, Cisco has other protocols that it sends out by default.
Giuseppe Larosa
Hello @Kevin Hamilton ,
I agree with @Joseph W. Doherty  your device interface is sending packets or frames with a multicast destination and CDP is the major candidate because the last input says 17 seconds that would be too much for any form of STP.
Hope to help
Giuseppe
Thank you both for your responses.  Based on what you're saying, this isn't anything I need to worry about.  I realize I can choose to disable CDP, but I assume that is not necessary.
Thank you and stay well.
Kevin
