About SFP In C9200L
stpc0422
Can we use SFP-10G-T-X on 10G network module of catalyst C9200L-24T-4X-A ?
Hi @stpc0422
It seems it does not work. If you check on the sfp compatibility matrix the sfp is not there.
 Further more, there was a discution here last year about the same setup with someone from cisco saying it does not work. You make look the post
https://community.cisco.com/t5/optics-and-optical-networking/sfp-10g-t-x-compatible-for-catalyst-9200/td-p/4574581
Thanks A Lot!  Any Alternative?
If you have the SFP I believe you should try use it. But I did not find any SFP on the cisco doc.
M02@rt37
hello @stpc0422,
here the matric compatibility for your C9200L-24T-4X-A
https://tmgmatrix.cisco.com/?npid=1771
You can not use  SFP-10G-T-X.
What is the network equipement on the other side ?
Best regards
