SFP-10G-T-X compatible for catalyst 9200
adeebtaqui
Level 4
Level 4
Can we use SFP-10G-T-X on 10G network module of catalyst 9200
10 Replies 10
balaji.bandi
yes it supports, make sure you have the correct Module in place :
Network module part numbers and descriptions  (C9200-NM-4G - this is only 1GB module)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html
BB
The 9200 module is C9200-NM-4X.
The problem is sfp compatibity matrix does not show  SFP-10G-T-X   for   C9200-NM-4X
what is the exact module SKU?
if it is C9200-NM-4X official matrix not displaying under compatible list. check.
https://tmgmatrix.cisco.com/?npid=1766
Good luck
KB
marce1000
     - Not according too : https://tmgmatrix.cisco.com/?npf=341  and or verify compatible SFP-list.
 M.
adeebtaqui
Level 4
Level 4
Has anyone tested as compatibity matrix may have missed to update
I have tested on Cat 9300 with that Module.(8X)
BB
I have tested on C9200L-48P-4X-E (Cisco IOS XE Software, Version 17.03.03)
and it works fine. Not sure why it isn't listed. I believe it used to be listed.
In fact it shows up as a SFP-10GBase-CX1 when showing status
I use them at a remote site for 10G copper trunk to VM Host Virtual switch.
pindey
No, as on 18th July 2022
Can you offer more insight to this response?
Because @chris.gaffney got it to work.
I tested it with IOS 17.03.04, 17.06.04, 17.09.02 on C9200L-48P-4X-E with original Cisco SFP-10G-T-X- not working with any of these. There are some C9200L models listed in compatibility matrix, but C9200L-48P-4X-E is not there. For the listed switches min compatible IOS version is 17.09.01 and I was hoping C9200L-48P-4X-E will also be working after IOS upgrade, but it's not. It's a great disappointment of 2960 series replacement.
