AR-XP Trunk Monitoring
Emyrsonn Rodil
How can show internode connection with  AR-XP 10G-trunk do carry 10G traffic? Is there a way to view it thru CTC?
As check in PM section it just showed errors not the trunk bandwidth.
Thanks...
kayukovvalera
It's impossible to check bandwidth of trunk or client utilization in CTC, trunk ports on this card have fixed bandwidth OTU2.
thanks for the response... What we did is configure the AR-XP as Hi-rate transponder. Connect a 10GE LAN tester and monitor the thoroughput...
