12-11-2020 03:52 PM
Hi Network Gurus,
Can you kindly help, google did not help much, is there a way to summarize received BGP from the neighbor, aware of summarized routes that can be send, but can't find anyway i can summarized received routes.
example
If i'm receiving a flood of prefix from AS2000 and want to summarize only on AS1000
B 192.100.100.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.11.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.12.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.13.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.14.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.15.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.16.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.17.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.18.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.19.0/24 [20/0] via 172.168.11.1, 00:00:15
B 192.168.20.0/24 [20/0] via 172.168.11.1, 00:00:15
Thanks in advance, appreciated.
12-12-2020 01:01 AM
Look at the example below and understand the concept :
here is an example for you to fix things :
router bgp 100
bgp log-neighbor-changes
network 172.16.0.0 mask 255.255.254.0
neighbor XXXX remote-as YYYYY
ip route 172.16.0.0 255.255.254.0 Null0
12-15-2020 07:39 AM - edited 12-15-2020 07:40 AM
Hello @TsepoLeribe ,
bgp aggregate-address summary-only can be used for this
you can aggregate routes that share a common part of the network portion in binary for example
192.168.16.0/24
192.168.17.0/24
192.168.18.0/24
192.168.19.0/24
can be aggregated in
192.168.16.0/22
router bgp 1000
aggregate-address 192.168.16.0 255.255.252.0 summary-only
be careful in creating summary routes that include component routes that do no exist.
Hope to help
Giuseppe
