C897Va to ISP Modem
billybong
Hi all
Could someone please check my config as i'm not getting any pings back
My idea is use a dialer to connect to the modem to access the internet, the modem was supplied by the ISP
sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  administratively down down
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
Dialer0                    unassigned      YES NVRAM  up                    up
Dialer1                    unassigned      YES unset  up                    up
Ethernet0                  unassigned      YES NVRAM  administratively down down
GigabitEthernet0           unassigned      YES unset  down                  down
GigabitEthernet1           unassigned      YES unset  down                  down
GigabitEthernet2           unassigned      YES unset  down                  down
GigabitEthernet3           unassigned      YES unset  down                  down
GigabitEthernet4           unassigned      YES unset  down                  down
GigabitEthernet5           unassigned      YES unset  down                  down
GigabitEthernet6           unassigned      YES unset  down                  down
GigabitEthernet7           unassigned      YES unset  up                    up
GigabitEthernet8           unassigned      YES manual up                    up
NVI0                       unassigned      YES unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      X.X.X.X YES NVRAM  up                    up
interface GigabitEthernet8
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address XXXXXXXX
interface Dialer0
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ppp mtu adaptive
ppp authentication chap pap callin
ppp chap hostname XXXXX@XXXXX
ppp chap password 7 XXXXXXXX
ppp pap sent-username XXXXX password 7 XXXXX
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no cdp enable
interface Dialer1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
dialer-list 1 protocol ip permit
control-plane
Hi Guys, this is now up and running, it turns out we needed a sub-inteface on G8 with vlan 40
Thanks for the help i have added stars :)
interface GigabitEthernet8.40
encapsulation dot1Q 40
no ip redirects
no ip proxy-arp
no cdp enable
interface Vlan1
ip address X.X.X.X 255.255.255.0
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ppp authentication pap chap ms-chap callin
ppp chap hostname X.X.X.X
ppp chap password X.X.X.X
no cdp enable
27 Replies 27
billybong
anyone?
Look at the good example and solution recent post: you need nat inside and our side interface configured and match the NAT ACL.
https://community.cisco.com/t5/routing/887va-vdsl2-configuration-problem/m-p/4114203#M336534
BB
hey balaji thanks for the link but no luck i'm afraid even after adding the sub-interface
I've included the bebug below
*Jul 7 00:01:17.027: pppoe_send_padi:
contiguous pak, size 60
FF FF FF FF FF FF 00 2C C8 56 7C 76 88 63 11 09
00 00 00 10 01 01 00 00 01 03 00 08 C7 00 00 02
00 00 11 4C 00 00 00 00 00 00 00 00 00 00 00 00
*Jul 7 00:01:17.027: PPPoE VLAN CoS (pppoe_client_send_padi)=>GigabitEthernet8.
1 :: cos=0x0
This is my current config
no ip address
duplex auto
speed auto
interface GigabitEthernet8.1
encapsulation dot1Q 1 native
interface Vlan1
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ppp chap hostname mypassword@mydomain
ppp chap password 7 my password
no cdp enable
interface Dialer1
no ip address
shutdown
ip http server
ip dns server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit X.X.X.X 0.0.0.255
hostname#sh ip int brie
ocol
Dialer1 unassigned YES unset administratively down down
GigabitEthernet8 unassigned YES NVRAM up up
GigabitEthernet8.1 unassigned YES unset up up
any help is welcome, i'm going wrong somewhere just can't put my finger on it
Just to clarify as per the original post you able to connect to DSL and you are not getting the Internet ? or am i miss understood wrong here?
can you post complete show run here and let us know who is your provider?
BB
the device i need to connect to is a Huawei HG8012H which appears to be ONT if that helps
sh run from the C897
Router#sh run
Building configuration...
Current configuration : 2697 bytes
version 15.5
service password-encryption
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip name-server X.X.X.X
ip cef
no ipv6 cef
license udi pid C897VA-K9 sn X.X.X.X
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
duplex auto
speed auto
interface Vlan1
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ppp chap hostname X.X.X.X @X.X.X.X
ppp pap sent-username X.X.X.X @X.X.X.X password X.X.X.X
D20
no cdp enable
interface Dialer1
no ip address
shutdown
ip http server
ip dns server
ip route 0.0.0.0 0.0.0.0 X.X.X.X
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input none
scheduler allocate 20000 1000
end
Router#
Thanks for the help so far balaji
anyone?
my isp is M.net germany
try
config t
default interface GigabitEthernet8
interface GigabitEthernet8.7
encapsulation dot1Q 7
no ip route 0.0.0.0 0.0.0.0 X.X.X.X
BB
hi balaji , i tried a sub-interface lastnight but it made no differnce
Its strange even debugging only gives the below info, no negotiation process just the below
1 :: cos=0x0
can you post complete config after modification of the latest config, please?
BB
Hi balaji, i have to wait until tomorrow as i'm not on site at the moment, will post it then
Router#sh run
Current configuration : 2611 bytes
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
interface Vlan1
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ppp chap hostname X.X.X.X@X.X.X.X
no cdp enable
interface Dialer1
no ip address
shutdown
ip http server
ip dns server
control-plane
vstack
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
end
Router#
anyone have any ideas ?
