C897Va to ISP Modem
billybong
Hi all
Could someone please check my config as i'm not getting any pings back
My idea is use a dialer to connect to the modem to access the internet, the modem was supplied by the ISP
sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  administratively down down
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
Dialer0                    unassigned      YES NVRAM  up                    up
Dialer1                    unassigned      YES unset  up                    up
Ethernet0                  unassigned      YES NVRAM  administratively down down
GigabitEthernet0           unassigned      YES unset  down                  down
GigabitEthernet1           unassigned      YES unset  down                  down
GigabitEthernet2           unassigned      YES unset  down                  down
GigabitEthernet3           unassigned      YES unset  down                  down
GigabitEthernet4           unassigned      YES unset  down                  down
GigabitEthernet5           unassigned      YES unset  down                  down
GigabitEthernet6           unassigned      YES unset  down                  down
GigabitEthernet7           unassigned      YES unset  up                    up
GigabitEthernet8           unassigned      YES manual up                    up
NVI0                       unassigned      YES unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      X.X.X.X YES NVRAM  up                    up
interface GigabitEthernet8
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address XXXXXXXX
interface Dialer0
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ppp mtu adaptive
ppp authentication chap pap callin
ppp chap hostname XXXXX@XXXXX
ppp chap password 7 XXXXXXXX
ppp pap sent-username XXXXX password 7 XXXXX
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no cdp enable
interface Dialer1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
dialer-list 1 protocol ip permit
control-plane
27 Replies 27
I don't think your setup is going to work unless the ISP provided modem is configured in bridge mode. What model/type is the modem ?
The config below (important parts marked in bold) should allow a ping from GigabitEthernet8 to anything on the Internet e.g. ping 8.8.8.8 source-interface GigabitEthernet8). For the rest (the Vlan 1 subnet) to have Internet connectivity, you need a route back to that subnet from your ISP modem...
Router#sh run
Building configuration...
Current configuration : 2611 bytes
version 15.5
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
--> ip address dhcp
--> ip nat outside
duplex auto
speed auto
interface Vlan1
ip address X.X.X.X 255.255.255.0
--> ip nat inside
interface Dialer1
no ip address
shutdown
ip http server
ip dns server
--> ip nat inside source list 1 interface GigabitEthernet8 overload
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
access-list 1 permit X.X.X.X 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input none
scheduler allocate 20000 1000
end
thanks for the reply Georg
the fiber box is a Huawei HG8012H assuming this is in bridge mode what would i need to do as the above config still isn't working still, i'm not recieving an IP address on int G8
GigabitEthernet8 is up, line protocol is up
Hardware is PQ3_TSEC, address is 002c.c856.7c76 (bia 002c.c856.7c76)
Internet address will be negotiated using DHCP
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:08:38, output 00:00:08, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
2 packets input, 128 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
Thanks for help
FYI the ISP supplied a /32 address which im finding strange
if you are sure th modem is in bridge mode, try the config below:
interface Ethernet0
no ip address
no shutdown
interface Ethernet0.101
encapsulation dot1Q 101
no ip redirects
no ip proxy-arp
no shutdown
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ppp authentication pap chap ms-chap callin
ppp chap hostname mypassword@mydomain
ppp chap password 7 my password
no cdp enable
ip nat inside source list 1 interface Dialer0 overload
thanks for the config, i'm assuming i need to move the cable from port G8 to E0?
There should be an ADSL/VDSL port on the router, that is where the cable needs to go...
thats the problem i'm unable to use that port as its not an rj45 connection
the current setup is fibre to the Huawei HG8012H from the Huawei its cisco C897Va router
I just remember that M.Net in Germany used to work only with Fritzboxes. That might still be the case and also the reason there is no configuration to be found for the Cisco 897VA and M.Net. Can you give them a call and verify if your router works at all with their network ?
Thanks I'll try to get in touch with them and let you know the outcome
Hi Guys, this is now up and running, it turns out we needed a sub-inteface on G8 with vlan 40
Thanks for the help i have added stars :)
interface GigabitEthernet8.40
encapsulation dot1Q 40
no ip redirects
no ip proxy-arp
no cdp enable
interface Vlan1
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ppp chap hostname X.X.X.X
ppp chap password X.X.X.X
no cdp enable
As per my knowledge they were using VLAN, that is the reason i propose subinterface with vlan 7 before may it was old one, now they use VLAN 40
good to know all working.
BB
it would appear so thanks again balaji :)
Glad all working as expected.
BB
