C9200L-24P-4X-E - GLC-GE-100FX
RRFS578780
I have a problem recognizing the GLC-GE-100FX for the catalyst C9200L-24P-4X-E fast interface.
Can't find if it's supported or not or if it has any specific setting to enable SFP or version restriction
marce1000
 - To find compatible SFP's for your device go here : https://tmgmatrix.cisco.com/
 M.
Leo Laohoo
What firmware is the switch on?
When the optics get inserted into the port, what does the log say?
If the RX gets looped into the TX, what happens to the port/LED?
NOTE:  The TMG Compatibility Matrix is no longer a reliable source of information because it is no longer being updated regularly.
BrianSekleckiGE
I recently tested / validated [ GLC-GE-100FX V02 ]  on [ C9200-24P ] + [ C9200-NM-4X ] running [ IOS-XE v16.12.4 ]
However, v02 of this SFP lacks DOM (Digital Optical Monitoring), so I recommend at least V03
Did you ever solve your problem?
