03-18-2015 09:50 AM
Can I Connect MM Equipment to a MM Switch using SM Fiber Optic?
I know the correct way is use MM fiber, But Could I Use SM fiber optic to connect a equipment that have MM port to our switch that have MM port?
Thanks!
03-18-2015 09:55 AM
Core of SMF smaller than MMF, it mean that you will get errors. Then port will error disabled. I will not work at all.
03-23-2015 08:48 PM
SFP made for MM fiber is not going tp work over SM fiber.
