Cisco 892 how to check speed sync
In other terminal like 870 I use command "show dsl interface atm 0" but now we have a cisco 892 with OF acces. How can I cheeck the current line speed?
Leo Laohoo
You're probably using an 877 when you can run this command.  The 892 can't run this command because the WAN interface is an ISDN BRI/PRI interface.
I haven't played with ISDN for awhile so try "sh isdn ?".
No, it's Gigabit Ethernet WAN. BRI for backup but in practice nobody uses that anymore.
Thanks Paolo.
paolo bevilacqua
Speedtest.net
