Cisco cisco WS-C3650-48PD I want to order SFP transceiver
mmwa
I'm looking for Cisco cisco WS-C3650-48PD & cisco WS-C3650-24PD SFP transceiver for LC-TO-LC type I got terminated 12 core fiber cable and I want to connect SFP transceiver from these switches to Cisco 9500 switch. can anyone suggest me which SFP module I should order.
for C3650 you can use GLC-SX-MMD for 1Gbps - https://tmgmatrix.cisco.com/?npid=447
for 9500 also you can use GLC-SX-MMD. use compatibility tool above to search for specific device model and compatible transceivers.
Good luck
KB
marce1000
              - Go here to find compatible SFP's for your devices : https://tmgmatrix.cisco.com/
 M.
Good luck
KB
Thank you
