09-10-2004 01:53 AM
I have some problems to use a GBIC 1000Base-ZX on a cisco 3750.
With some research , i have find these thing :
The Catalyst 3750 models support these Cisco SFP options:
1000BASE-LX
1000BASE-SX
1000BASE-T
1000Base-ZX didn't appear.
What do you think of such thing.
Thanks for help
09-10-2004 04:16 AM
The 1000BASE-ZX SFP (Cisco product number GLC-ZX-SM=) is supported on the Catalyst 3750:
Cisco Optical SFP Transceiver Compatibility Matrix
List price in the US is the same as for the 1000BASE-ZX GBIC (Cisco product number WS-G5487=)
It's possible that the information you have found has not been updated yet. I believe the ZX SFPs were among the last ones to become available. The Release Notes in the link below are the first ones to mention this SFP, they refer to it as "new hardware" (versus the SX and LX SFPs):
Release Notes for the Catalyst 3750 Switch Cisco IOS Release 12.1(14)EA1 July 2003
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12114ea1/ol421501.htm
Hope this helps.
09-10-2004 06:53 AM
Thanks for your response
What is the minimum IOS required for 3750 to run
SFP GLC-ZX-SM ?
09-10-2004 10:42 AM
First documented support for SFP GLC-ZX-SM: Release 12.1(14)EA1, 05-September-2003
Current recommended minimum IOS: Release 12.2(18)SE, 26-April-2004
Current IOS for the Catalyst 3750: 12.2(20)SE1, 19-July-2004
