Configuration of two routers connected with dark fiber
carlman001
This is a case of a company with 3 branches. Two of these braches are connected with dark fiber.
The network admin didn't prefer to use VPN IPSEC to connect the branches each other.
He preferred to use dark fiber.
If I design by Packet tracer two routers connected with fiber. Each router represents one branch. Is this design would be a good way to simulate dark fiber?
Other questions:
Why VPN IPSEC would be slower than dark fiber?
Does dark fiber work as point-to-point wan topology?
Is there a web page with an example about how to configure two routers using dark fiber with packet tracer?
Can each router be configured with the same network segment for private IPs using dark fiber?
2 Accepted Solutions
balaji.bandi
Dark Fiber is plan Ethernet cable, any Middle of attach can be possible, ( if you have latest Switches, you can enable MAC Sec on Layer 2)
ther questions:
- Not slow, it require encap and decap, than plain Layer 2, New hardware you would not see major speed issue, they process in good in hardware.
- Dark Fibre, means provider giving layer 2 fibre between, depends on provider terminology again.
- PT emulator ? you need to just use Layer 2 connection ethernet connected between devices
 - yes Layer 2 means same broadcast domain or VLAN, how you looking to deliver and configure your choice.
BB
Tom Randstrom
Think of dark fiber as just a long optical patch cord being plugged into an optical transceiver in a line card. You can provision services over the fiber just as you would between any two fiber connected devices.
balaji.bandi
ther questions:
BB
Tom Randstrom
