connect SFP+ module to FPGA board
benjemaa
Hello everybody,
I want get 1 to 10G Ethernet data from the network to my FPGA for processing.
My FPGA transceivers support both 1GBASE-T and 10GBASE-T ethernet standards
The network should connect to my FPGA via electrical twisted copper cable. (RJ45)
I am using therefore the SFP+ GLC-T.
1) How can I configure the SFP+ module to work?
2) how can I tell the SFP+ that now I am switching from 1Gbps to 10Gbps data rate and vice versa.
Thank you :)
heath762
If your FPGA supports sfp+ you would need to make sure you are using a supported sfp+ model/manufacturer for your hardware.
Your network device needs to support 10Gbase-T as well.
What model switch are you connecting to?
