Resolved! SFP-10G question
Does it work if I connect the SFP-10G-SR to SFP-10G-LRM using 10G multimode fiber?
Hi. Can anyone verify that the Cisco15454 has the ability to be monitored via multiple TL1 TCP/IP Connections? And if so, do you use different port number for each connection? Also if the older Cerent devices are also able to do this?
Hi, im Victor and im having two problems in a switch, from one side i have a switch A te2/0/2 connected to a Switch B te2/0/2, the switch sometimes blink orange Green, and sometimes is blinking Green only. If the port ar runing a few hours, it sudde...
I've recently upgraded a stacked pair of WS-C3850-12XS switches to version 03.07.05E. Following the upgrade, the primary switch in the stack no longer recognises the SFP's connected in ports 1/0/1 & 1/0/6. The secondary device has SFP's connected in ...
I have Purchased 1572 outdoor AP (AIR-CAP3702E-C-K9). How can i power up in this AP. Because there is no PoC, DC power cable with this AP. and also i have no PoE connection by which I can power up this AP. But I have Fiber connection for SFP. So is i...
A few years ago I was close to gettting my CCNA with my first AAS degree. I just recently got a few switches. I just acquired a Cisco MDS 9148 Fiber switch. Its very very cool. What can I do with it?
Hi, Can any one tell me possible reasons if Fiber light levels with in range but Layer 1 still shows down on both source and destination routers, what could be reason? Considering there is a partner in between and a colocation as well. Just want to ...
Hello The IEM-3000-8FM is an expansion module with 8 100BASE-FX fiber-optic Ethernet ports. This module is used with the I300 series switches. I need to know the wavelength (850 nm or 1300 nm) supported by the ports. At the other end of the line, ...
We've a setup including Nexus 5624Q and Catalyst 2960X-48TD-L (which has 2 SFP+ ports), and breakout cable Cisco QSFP-4X10G-AOC10M was used to connect 5624Q to 2960X's Te1/0/2 port. Appears the cable is not recognized by 2960X, with error messages li...
Hello, I have two different Cisco switches that need to be connected with optic fiber. The models are: Cisco Catalyst 2960xCisco Small Business SGE2010P The fiber specs are: monomodeLC/LC terminalsmini Gbic My question is: what modules should I buy t...
Hi I had a new Single mode Fiber 1gb pipe ran to my cabinet in Telx datacenter. I wanted to install a Cisco switch with gigabit interface sfp and 3 routers. Basically I want to install the single mode fiber link from my ISP into the Cisco switch Upl...
Hi, I'm looking for the validated design and best practise solutions for designing and implementing cisco GPON technology (ME4600 OLT and ONT-RGW) on a large mall or campus. could you please help me with this? I also want to know how to configure,man...
Can we put two Gigabit Interface Converter (GBIC) for fiber in the SG112-24? There was a comment for the combo mini-GBIC slots that leads us to believe only one GBIC can be used on the switch:"*Each combo port has one 10/100/1000 Ethernet port and on...
Hi We have new IE-3010-16S-8PC Cisco router. We have bought new SFP modules (GLC-FE-100LX) for this device. But when we insert these SFP modules in router nothing happens in console, there is no reaction at router at all. So when we connect ethernet...
I have a WS-C2960CX-8PC-L switch and a DWDM-SFP-4056 GBIC. If I'm reading http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc476298501 right then they should be compatible. However, ...
Subject | Author | Posted |
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM | ||
03-27-2024 12:16 AM | ||
03-27-2024 12:09 AM | ||
09-10-2023 08:07 AM |
