04-19-2007 10:15 AM
Hi, i got a problem with an ONS 15454, when i access the CTC local view of the equipment the system say that it loss connection and change the local view to a network view. The node shows a grey color and it could be accessed again after two minutes.
My CTC version is 7.0.0 and my computer is running Windows 2000.
Solved! Go to Solution.
06-27-2007 06:10 AM
It's a network problem.
You have a firewall into your network.
You need to go from CTC on network parameters (provisioning --> network) and setup:
Enable SOKCS proxy
SOCKS proxy only.
This should work, but take care about your network topology.
E.G.: if you have some other host NOT 15454 connected to your network it's possible that you lost them.
04-19-2007 12:42 PM
Does the node icon display the node name or the IP address when CTC loses connectivity?
How are you connecting to the node? Via TCC Port? LAN? DCC? Through a firewall?
There are two possibilities:
1. Gray with node name = Node is initializing
2. Gray with IP address = Node is initializing; a problem exists with IP routing from node to CTC or your login/password is not provisioned on this node
I suspect you have a problem with the Java/CORBA session being interrupted and causing CTC to reinitialize the node in the session.
04-19-2007 02:17 PM
CTC show a window titled "CTC Alert", where it shows a message of "Lost connection to nodeName, changing to network view", and the Node icon display the node name.
I suppose that node is initializing at software level, because i have not problems with physical optic comunication.
Right now i?m trying to connect to ONS by LAN on the TCC2P LAN port, but this problem also happen even when i connect a Laptop directly to the TCC2P LAN port or MIC-C/T/P LAN port.
06-27-2007 06:10 AM
Enable SOKCS proxy
SOCKS proxy only.
