10-24-2013 06:02 AM
Dear All,
I have to interconnect my datacenters. I need to have SAN connectivity between datacenters. I am using Brocade 2499-192. Will CWDM-MUX8A supports brocade? Please let me know!
Pramod
10-24-2013 08:39 AM
If the brocade device supports CWDM optical transceivers (SFP or other), then you can use the cisco CWDM mux/demux.
11-01-2013 01:44 AM
Dear Tom,
I would like to add cisco 4500 series switch. Please let me the compatible line cards and sfp's to connect to Mux.
Rgds,
11-01-2013 05:29 AM
The following URL provides Cisco CWDM transceiver compatibility with various hardware.
The following URL provides links to the Cisco transceivers.
Good luck!
12-22-2013 02:16 AM
- Brocade officially does not support CWDM SFP, and you need bay or get for test Third-party SFP for test. If test failed you need to bay this transponder for Brocade:
- Also depends on distance you need to get Brocade Extended Fabrics License and Brocade ISL Trunking License for your Brocade switch.
- Chouse correct platform with enof buffer credits and calculate how mane you need.
Brocade administration guide:
http://www.brocade.com/downloads/documents/product_manuals/B_SAN/FOS_AdminGd_v720.pdf
Bufer credit calculation, page 8
Platform buffer credit allocation, page 15
Licensing, page 37
If you need I could help you with cisco specification.
