Diagnostic Monitoring is not implemented
anasubra_2
Hi All,
We are trying to find the reason and solution for the below problem. We are tring to perform the below command and get the below message.
router#show interfaces gigabitEthernet 5/1 transceiver
Diagnostic Monitoring is not implemented.
The module on which the above gig interface is WS-X6408A-GBIC and the IOS version running on this router is s72033-advipservicesk9_wan-mz.122-18.SXF11.bin. The sup on this router is SUP-720-3BXL.
Any help to understand why it is giving that message and the solution to overcome the same would be really appreciated.
Anantha Subramanian Natarajan
WS-X6408A-GBIC --Module 5
SUP-720-3BXL
Tom Randstrom
Which GBIC optical modules are you installing into the WS-X6408A-GBIC? The following document outlines the DOM support by hdwe and software.
Cisco Digital Optical Monitoring Compatibility Matrix
<http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html>
Hi baileyshbr,
Thank you very much and I have to check the GBIC's .
s-01-pnh-asr#sh interfaces gigabitEthernet 0/25 transceiver detail
Can't see anything.
