Hello. We have many cisco 3560G switches running 12.2(46)SE. Several of the switches are on cwdm fiber links. We would like to be able to query the SFP's to see what their optical values are. I am told by a cisco optical person...
I have an ML-MR 10 card. I cannot figure out how to get the ONS 15454 to recognize it. I insert the card. I then the card and right click. I go to Ethernet and there is not an ML-MR Card. There is a ML1000 and an ML1000T. I really am not sure...
Hello all,I am looking to find out the different ways to check power levels of the different wavelengths using CTC. When I cable up the different optics on the CE devices, I want to be able to log into the CTC and check to make sure the power levels...
Hi ,We have a couple of these SPF transceivers which we have not use for a a while ie a year or two.Now we want to use them but how do we test it to see if it is still working ???ThanksQLE
I am in despeate need of some assitance in connectng to my 1545. We upgraded our software and now the lights on the 1545 just blink. I do not know if I can connet to this via the rs232 connection or not. I am not sure if somehow I can get the ...
We have a 4 node ONS15454 MSPP UPSR ring running 8.5.4 software. We are running the usual mix of DS1 and DS3 circuits, however I'm trying to standup some ML1000-2 cards to be used to transport some Ethernet circuits across the rin...
According to the TL1 document for 15454, COPY-RFile command denotes that FTP timeout is 30seconds and it is not configurable. I have the following questions on this.Is the timeout for creating a connection to the FTP server or for the total command e...
Hi everyboby,in the office we have 4 switches SG200-26 all connected ones between them in fiber.Only one however it has problems with mini-gbic SFP transceiver, if inserted it doesn't ignite any red light.Can he depend on a hardware problem only or d...
Hi everyone,I have two new Cisco switches connected to each other with a fibre cable.Does anyone know any CLI commands to test the fibre cable from any of the two switches?(I know there is the command "test cable-diagnostics ... etc". But, this only...
Dear all,we want to read the full EEPROM information of a SFP+ which is within a C3KX-NM-10G network module within our Cisco Catalyst 3750-X switch. IOS is 15.0(1)SE.I just found the "show idprom interface tengigabitethernet x/x/x detail" command, bu...
Hi,I am sorry if this topic has been up before. I am rather short on time so I need to get this cleared asap. I wonder if the 1000BASE-LX work with the 1000BASE-LH GBIC? Unfortuneatly the devices are remote so I don't have anything more to go on than...
Hi All, We are trying to find the reason and solution for the below problem. We are tring to perform the below command and get the below message.router#show interfaces gigabitEthernet 5/1 transceiver Diagnostic Monitoring is not implemented.The modu...
Hi all :The whole picture is as below:One side of fiber port from Cisco AP 1240AG is converted to Multimode Fiber 100MBit so that it to travel long distance to 1G port of WS-C2960S-48LPS-L. My question here is whether the SFP of model GLC-GE-100FX ca...
Dear all, I have 2 module :Cisco 1000Base- LX/LH SFP . Sw 3560E ( Top-Wig ) Sw 4510R . I want to connect 3560E to 4510R by fiber optical (Singer mode -distance 3km ) use module :Cisco 1000Base- LX/LH SFP. But when plug module to Sw 3560E (To...
I am to plan and roll out a fibre network across london for my company. We require fibre router / switch at our at our 2 data centre. These will have lots of space for use to slot in cards for whatever puspose we need, single / mutimode fibre, dark ...
Subject | Author | Posted |
10-07-2024 12:40 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
