06-10-2024 08:54 PM
What is different of GLC-FE-100FX-RGD V01 GLC-FE-100FX-RGD V02 and GLC-FE-100FX-RGD V03?
Is there any offical documentation to explain it?
I want to know what excatly item to each version.
THX
06-10-2024 10:23 PM
As per operation concern there is no difference, all works as expected (only version of release different ) VID - just version.
you can check only Field notice if any example :
https://www.cisco.com/c/en/us/support/docs/field-notices/642/fn64225.html
06-11-2024 08:22 PM
I am sure there is different between them . According the last table ,item "notes" on this website
https://copi.cisco.com/?tpid=47
"DOM support for V03 or later"
I got some GLC-FE-100FX-RGD V02 and they really don't support DOM . It makes me wonder to know what else different between them and I want to get a offical document to prove this. FOR EXAMPLE "GLC-FE-100FX-RGD upgrade history"
06-12-2024 12:31 AM
- Hardware revisions are not documented (for public use) ; unless there is a specific need such as in field notices to point to a specific revision when needed for a particular connection on a switch model (e.g.)
M.
06-12-2024 03:33 PM
personally never seen GLC-T dom support nor i have seen it : official the document says NO
06-11-2024 12:01 AM
- These refer to hardware revisions of the particular SFPs ,
M.
