How to connect a SXGbic to a fibre nic (server)
sirjohnbeano
Can I connect a SXGBIC (WS-G5484 or WS-G5486) to a fibre nic which is located into a server (win2008).
If its possible, what specifications must the NIC have.
Thanks in advance.
Beano
5 Replies 5
Tom Randstrom
As long as the two end points use the same protocols and transceiver specifications, you can interconnect them.  Make sure the server NIC is 1000Base-SX compatible (if using WS-G5484) or 1000Base-LX compatible (if using the WS-G5486).
Thanks Tom,
Can you help me what kind of protocols and specifications I have to look for ?
rgs,
Beano
Do you have a link to information regarding the Server NIC?
I don't have one.
Example, I found a one HP Storageworks with Partnummer 250176-001 Is it possible to connect this ?
Specs
Speed = 2048 Mbps
64-bit PCI
Chipset Emulex FCA2101 (Emulex LightPulse Fibre Channel SCSI)
I can find which specs I have to look for.
Beano
You need a NIC that supports Gigabit Ethernet, IEEE 802.3z standard, to interconnect with the Cisco Transceiver part numbers you outlined in your original posting.
