ā06-28-2024 11:36 PM
Hi engineers
i have two switch core (twe1/0/2) and L2(Te1/1/8) connected connectivity is fluctuating
here is some logs
i have check interface transceiver on both switch
what can i do so connectivity can be stable ?
your response will be appreciated
thanks in advance
ā06-29-2024 12:47 AM
- You may have a simple (layer1) connectivity issue
+ Take another SFP
+ Swap fiber (patch) cable , if possible
+ Make sure connections are solid
+ Look at interface port counters for the involved connections
M.
ā06-29-2024 03:10 AM
ā06-29-2024 03:43 AM
Post the complete output to the following commands:
sh interface Ten 1/1/8 controll
sh interface Ten 1/1/8 trans proper
