how to fix switch interface connectivity.
Bijay Singh
Hi engineers
i have two switch core (twe1/0/2) and L2(Te1/1/8) connected connectivity is fluctuating
here is some logs
i have check interface transceiver on both switch
what can i do so connectivity can be stable ?
your response will be appreciated
thanks in advance
marce1000
  - You may have a simple (layer1) connectivity issue
              + Take another SFP
              + Swap fiber (patch) cable , if possible
              + Make sure connections are solid
              + Look at interface port counters for the involved connections
 M.
Leo Laohoo
Post the complete output to the following commands:
sh interface Ten 1/1/8 controll
sh interface Ten 1/1/8 trans proper
