HPE SFP+ compatibility with Cisco SFP+ ???
Tagir Temirgaliyev
I want to connect HPE server and Cisco switch with MM patch cord.
in HPE server I want to install SFP+ Transceivers HPE BladeSystem c-Class 10Gb SFP+ SR Transceiver 455883-B21
https://h20195.www2.hpe.com/v2/getpdf.aspx/c04111517.pdf
and I want to know which SFP+ module to install in Cisco switch
a)  Cisco 10GBase-SR
b)  HPE BladeSystem c-Class 10Gb SFP+ SR
johnd2310
Level 8
Level 8
You will need Cisco 10GBase-SR in the Cisco switch and multimode cable.
John
**Please rate posts you find helpful**
Klose2002
Cisco 10GBase-SR module is the way to go. Just follow the simple rule, use whatever transceiver module that compatible with the device it’s connected to. Could get a Cisco original 10G module or a Cisco compatible 10GBase-SR module from vendors like FS.COM: https://www.fs.com/products/11552.html. The later would hopefully costs 1/10 with equal performance.
The other thing you can do is use a Twinax (direct attach) cable with compatible transceivers on each end. Many times it is cheaper than piecing it together (although piecing it together does have it's advantages).
They are not ALL shown on the site, but we can put together almost any combination of twinax (or components) for you - www.cablesandkits.com.
Craig Haynie - CEO
CablesAndKits
